Did not show side value in chamfer command.
SK_9997310
I am using Creo Parametric 8.0 8.0.0.0
how can change the side value in the chamfer command but did not show the dimension value, Please find the attached snapshot in a jpeg file?
no
Requirement:
  • How to create edge chamfer for a specific portion of the edge?
Resolution:
  1. Create two dataum points on the edge between which chamfer has to be applied.
  2. Select the chamfer option and select the edge to apply chamfer.
  3. Select the transition option and select transition boxes highlighted and select the datum points as stop references
Requirement:
Resolution:
