New Creo user here and I have searched the forum already for this issue.
Every time I open a model, Part or assembly, it displays the style as 'Shaded'
I have to change it every time to 'Shaded with Edges'.
Is there any setting or option to keep the model 'Shaded with Edges''?
~Tushar
Set the config option:
display shadewithedges
Obviously this must be in a config.pro that is read when Creo is started.
Thanks a bunch @tbraxton for the hint.
I noticed that this setting already exists in the config.pro
I will check further and update here my findings.
