Re: the SW Dome feature - select a face, pull out a dome to a distance
Creo (2.0) doesn't have an exact match but what would you suggest as the nearest/quickest option.
I thought a blend could use a point as its final section?
Cheers,
Thanks for Mikessuggestions for the Solid Freeform or the Style Surface Edit. You can also add the obscure Radius Dome feature.
The problem with all these sub div based feature is they are OK if you are deform a rectangular surface as the sub div grid conforms to the base surface boundaries, as soon as you have a curved or tapering boundary the original edges get pulled off the plane non uniformly rather than creating a simple domed 'cap'
Creo and SW features are in the attached image, SW maintains the original surace boundary, Creo maintains the extents of the rectangular grid
