Drawing Symbols / Surface Finishes
RENEVDMERWE
Hi All How do I create my own Drawing Symbols,to use from the Drawing Symbols Palette,as it seems i can't save a .sym file Is there a quick way to do this. Thanx Rene
Rene Two answers, One you save symbols when you define them from a drawing. The symbol will be stored (write) in a folder that is shown in the message window or a new one that you choose. Second a palette is a drawing that you insert the symbols you want. Next you set your config.pro option to look for that drawing you created by name and location. That should get you going. Regards Eric Mills
