I am unable to set value for Height and width property of drawing table "As is". It actually appears into property page as soon as I set it, but once I come back to same again, that value is set to previous value instead of As is.
Thanks and Regards
Ketan
I think that you do not understand the meaning of (As Is) value. (As Is) tells you that selected entities does not share the same property.
For example:
Martin Hanak
Ketan,
please upload a drawing containing problematic table.
Martin Hanak
Refer Table 5 in sheet 4.
Unfortunatelly, your drawing does not contain sheet no. 4 with table 5. It contains 3 sheets every of them contains 4 views.
Apologies.. Refer sheet "With_4"
You did not tell me that the table is outside drawing border. This was the reason I did not see it.
Setting height/width for your table works as expected in CR2 M070.
Please try to reproduce my test.
Martin Hanak
I would like to set (As Is) for all four options. this I am able to do... Columns also I can set as As Is. Same is not allowed for Row values. In one of the file, I checked that all four are having As Is value, but unfortunately I cannot share that confidential file with you all. Attached is the reference document containing all values as "As Is"
For example:
Martin Hanak
