Drawing Table width and height "As Is"
Ketan_Lalcheta
I am unable to set value for Height and width property of drawing table "As is". It actually appears into property page as soon as I set it, but once I come back to same again, that value is set to previous value instead of As is.
Thanks and Regards
Ketan
I think that you do not understand the meaning of (As Is) value. (As Is) tells you that selected entities does not share the same property.
For example:
  • your table contains several columns with different width, therefore Height and Width dialog box contains (As Is) value
  • your table contains several rows with equal height 1.0, therefore Height and Width dialog box contains 1.0 value
  • if you change the height of row no.1 one to 2.0, select table and display Height and Width dialog box, the you will see (As Is) value set for rows
Martin Hanak
Martin Hanák
8 REPLIES 8
Ketan,
please upload a drawing containing problematic table.
Martin Hanak
Martin Hanák
Drw file is attached for reference.
Refer Table 5 in sheet 4.
Unfortunatelly, your drawing does not contain sheet no. 4 with table 5. It contains 3 sheets every of them contains 4 views.
Martin Hanák
Apologies.. Refer sheet "With_4"
You did not tell me that the table is outside drawing border. This was the reason I did not see it.
Setting height/width for your table works as expected in CR2 M070.
  • open the drawing
  • Activate Table tab
  • set selection filter to Table
  • select table
  • press RMB and use Height and Width command, you will see this contents
  • modify row height in number of characters to 2.0 and press OK
  • modify column width in number of characters to 15.0 and press OK
Please try to reproduce my test.
Martin Hanak
Martin Hanák
I would like to set (As Is) for all four options. this I am able to do... Columns also I can set as As Is. Same is not allowed for Row values. In one of the file, I checked that all four are having As Is value, but unfortunately I cannot share that confidential file with you all. Attached is the reference document containing all values as "As Is"
For example:
Martin Hanak
Martin Hanák
