Drawing View Display
kpietila
All,
I am trying to create some drawing views that will contain only certain features in each view or page.
Example. View 1 - a block.
View 2 (or sheet 2) - Block and a hole.
View 3 - Block, hole, and keyway.
The purpose of this is to use the original model, with inheritance feature, and create Op Sketches.
I am hoping to do this by resuming features in the model tree. Any thoughts on how to make this work?
I have tried Simp Reps, but that is not the intended functionality.
Thanks.
Kevin
I have had a couple of suggestions for Family Table. The issue is much more involved than the example provided. Thank you for those suggestions however. But I am really hoping to solve it with a solution that does not involve family tables.
Thanks again,
Kevin
