Drawing Zone in Repeat Region?
dbower1
I am using drawing zones... I want to report the Drawing Zone location of an item in a repeat region. Is this possible?
Thanks!
David Bower
1 REPLY 1
Is it possible to setup a note set and and parametric BOM to keep the
relationship of the note number to the item number ? So if you had a
column in your bom for "notes" that the corresponding note number in the
note set would update as additional notes where added and deleted.
Brian L Taylor
Sr Tech Support Engineer II
Engineering
SAS EL APC PMO Staff
Space and Airborne Systems
Raytheon Company
+1 972-344-7697 (office)
13510 North Central Expressway
Dallas Tx 75243 USA
www.raytheon.com
Follow Raytheon On
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
