Drawing problem.
CM10
Drawing problem.
Ok, management has just given us this totally unrealistic deadline (as usual): they want 30 e-size sheets done in less than 3 days! Now, if we could get half a dozen or more guys working on the same drawing at once, we might have a shot at it. I remember Intralink had a way to (I want to call it "reconcile") a model when 2 people had modified at the same time without locking it. Is there any way to do that with a drawing? I was thinking about doing the first 10 sheets, having the next guy do sheets 11-20, etc. Any ideas?
We're on WF3, M210, and (I think?) PDMLink 8.0.
Thanks.
2 REPLIES 2
You can have each person work on different sheets using different drawing files and then merge them into one when done
This is done all day - everyday in aerospace/defense/heavy equipment for projects on critical path - merge is fast and easy if certain rules are followed
CM10
(To:CM10)
Thanks to all for the input. I did a quick successful test, so that's the method we'll be using. Funny that in almost 13 years of using Pro/E I've never had the need to do this. I remembered something about being able to do something like that, but wasn't sure and the interface has changed so drastically since I took the training. I quess you learn something new every day! 🙂
