I like to insert a point where you are concerned about the clearance.
Run the mechanism and then select: Insert> Trace Curve
The resulting curve can be used in a drawing to measure the clearance.
In Reply to Doug Schaefer:
WF4, M100
I need to determine the clearance between two parts as one pivots around
another. The parts are assembled with mechanism constraints and will
move properly. I'd love to see the clearance on screen in a note and
have it change dynamically as I pivot the parts.
Best I can tell, however, I need to create an analysis feature for each
measurement I want, then create an annotation feature and within that
create a note and then enter the secret gibberish code
(&dim:FID_feature-name) to extract the dimension from the analysis
feature and then place the note someplace.
Is that it, or is there an easier way that I'm missing?
Doug Schaefer
Senior Project Engineer, Mechanical
Design Central
Columbus, Ohio
www.design-central.com http://www.design-central.com
614.890.0202
Confidentiality Notice
This is a transmission from Design Central Inc, Columbus, Ohio which may
be privileged and confidential, and thus is protected from disclosure.
This message is NOT intended for transmission to, or receipt by, anyone
other than the named addressee (or a person authorized to receive and
deliver it to the named addressee). If the reader of this message is not
the intended recipient, or an employee or agent responsible for
delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution or copying of this
communication is strictly prohibited. If you have received this e-mail
message in error, kindly accept our apology and please delete it from
your system without copying or forwarding it, and notify the sender of
the error by reply e-mail or by calling 614.890.0202 (collect).
