Easiest way to add restricted parameters to Models?
BHurler
Creo has neat functionality in the restricted parameter list.  Creo also has nice functionality in that you can import an .xml file to add parameters to a Model.  It would appear that these two do not play well together.
I am trying to update legacy models that have missing parameters and my .xml import was working wonderfully until I updated my restricted parameter.lst file.
I get this message:
Is there any way to make the import work?  Is it a matter of my restrictions in my .lst not EXACTLY matching what I have in the .xml?
VladimirN
(To:BHurler)
Article - "Full Access parameters used in relations cannot be imported via xml file in Creo Parametric 4.0": https://www.ptc.com/en/support/article/CS297809
VladimirN
(To:BHurler)
Hi @BHurler,
Anurag
