Creo has neat functionality in the restricted parameter list. Creo also has nice functionality in that you can import an .xml file to add parameters to a Model. It would appear that these two do not play well together.
I am trying to update legacy models that have missing parameters and my .xml import was working wonderfully until I updated my restricted parameter.lst file.
I get this message:
Is there any way to make the import work? Is it a matter of my restrictions in my .lst not EXACTLY matching what I have in the .xml?
Article - "Full Access parameters used in relations cannot be imported via xml file in Creo Parametric 4.0": https://www.ptc.com/en/support/article/CS297809
Hi @BHurler,
Anurag
