Explode Lines
Garred
Explode Lines
Is there any way to make the operations of cosmetic lines for explode views result in a standard way?
Is there anything being done to make what should be a simple feature work correctly?
Why do I not trust any community member when there are things like this being provided as solutions?
https://community.ptc.com/t5/3D-Part-Assembly-Design/Explode-Line-Issue/m-p/390043#M6732
It is frustrating to see that the issue I have in 2025 had been addressed in 2015, and the 'solution' to the issue was a link to a poll to try to convince PTC to care?
There is ZERO options to apply to make the cosmetic line for explosion views result in any sort of expected way.  I have attached a simple look at what can be the result of adding a cosmetic line 4 times in the same way.  The result should be 4 identical lines.  It is not.  This is a simple core feature used in all of CAD work.
Garred
(To:Garred)
Turns out it goes back further even.  Over a decade of knowing about the issue but being satisfied with the product they sell. 2013 should have been enough time to even look into this.
