I have an assembly which has several parts/sub assemblies. I want to get a complete bom table that i can import to excel. The problem is that some parts are shrinkwrap of an assembly and i want to list out the parts in those assemblies. I do find all the parts in the reference viewer but i manually need to expand the reference viewer and so far i have not find a great way to do this 🙂 When i do expand it all i get out this:
Reference #1:
CENTER_V -> 0265-0413-16.PRT -> SIDE -> Surface id 2
Reference #2:
CENTER_V -> 0265-0413-16.PRT -> FRONT -> Surface id 7
Reference #3:
CS0 -> 0265-0413-16.PRT -> FRONT -> Surface id 7
Reference #4:
CS0 -> 0265-0413-16.PRT -> SIDE -> Surface id 2
Reference #5:
CS0 -> 0265-0413-16.PRT -> TOP -> Surface id 5
Reference #6:
External Shrinkwrap id 32 -> 0265-0413-16.PRT -> 0265-0413-14.ASM
Reference #7:
External Shrinkwrap id 32 (Copied Ref) -> 0265-0413-16.PRT ->
0265-0413-14.ASM (Top Level) -> 0265-0413-06.PRT (comp id 4)
Reference #8:
0265-0413-14.ASM (Top Level) -> 0265-0413-13.PRT (comp id 8)
Reference #9:
0265-0413-14.ASM (Top Level) -> 0265-0413-26.PRT (comp id 14)
Reference #10:
0265-0413-14.ASM (Top Level) -> BUTT_WELD_ID_17 (comp id 17)
Reference #11:
0265-0413-14.ASM (Top Level) -> BUTT_WELD_ID_17 (comp id 17) ->
Weld Solid id 1
Reference #12:
0265-0413-14.ASM (Top Level) -> BUTT_WELD_ID_674 (comp id 674)
Reference #13:
0265-0413-14.ASM (Top Level) -> BUTT_WELD_ID_674 (comp id 674) ->
Weld Solid id 648
I have also tried to do it in windchill. Basically I want a list of all the parts and their parent assembly,
