Export to dxf
JoseIgnacioDiez
Export to dxf
One question
I´m trying to export a drw to dfx in version 14, the export is done correctly, but in my color.map I have a colour RGB(102,33,0). When I try to assign in the export enviroment for DXF/Properties/Colors, an Autocad Colour number 10, if i make it in this moment, it´s export ok.
How can i asign to the colour 102,33,0 in Pro/e, the color 10 in dxf, forever. There are any archive?
2 REPLIES 2
Hello Jose,
I guess you can only use 256 color pallete in dwg/dxf files.
Not quite sure. The dxf_export.pro file is still big unknown for me.
OK, in dwg/dxf exist 256 colors for example color 30=RGB(255,127,0) and color 3=RGB(0,252,0)
In my color.map, from the palette I add this color.
When I go to dxf export in version 14, I view this:
0,252,0 3
255,127,0 7
If I try to export in version 2004, all the colors are exported as RGB color, example:
0,252,0 3
255,127,0 255,127,0
In the dxf_export I can mapping the colors, example:
map_color LETTER_COLOR 3
I had tried to assign this:
map_color 255,127,0 30
When i try to export, (map_color 255,127,0 30), it doesn´t work.
Any ideas?
