Extracting Geometry from a Solid model assembly in Creo 5.0
NA_9941971
3-Newcomer
Hi All,
I have a step file of an assembly, and would like to extract a geometric feature (a set of curved surfaces) so that I can create a model based on them directly. I have found a similar solution on the support forums but the post is out-dated and vague, and I cannot get the solution to work on my system.
more details:
The copy Geometry button is greyed out, so is the publish geometry button.
Thanks, Nasim
1 REPLY 1
tbraxton
(To:NA_9941971)
Assuming that you do not have access to Copy Geom functionality I would suggest the following.
Create a copy of the surfaces you want to reference from the imported STEP solid geometry.
Determine a Csys that you can align to your derivative model you may want to create a new one rather than using the default Csys.
Export a STEP file and select only the newly copied surfaces for export.
Import the STEP export of your surfaces into a new part and use it to design your new part.
Guide to export a quilt using STEP interface, it is not intuitive in the UI.
https://www.ptc.com/en/support/article/CS260765?source=Case%20Viewer
Involute Development, LLC
Consulting Engineers
