Hi all,
I have a problem about Creo 3. Feature operations was really vital for me in Creo 2.0 but, in Creo 3 there is Flexible Modeling for it -i think-. I cant use it effectively. It works on surfaces not the solid. I mean when i want to transform something, i cant choose it from part tree. Shortly, is the name of feature operations changed or is it totally removed?
Thank you all.
Feature operations menu manager has been indeed removed from Creo 3.0, because PTC feels other functionalities made it redundant. If you're after copying solid features use Copy (or Ctrl + C) and Paste or Paste Special commands. If you want to use translate and rotate options you should go with Copy > Paste Special > check Apply move/rotate transformations to copies option to get dashboard with Move/Rotate options for copies.
feature operations i think you would get under-"operations" in creo 3.0
flexible modelling is for direct editing either ..non-native CAD data or native CAD data.
Yes normally it must be there but I have only these
could you name the options please?
Sorry, i did not get it ? Which options?
When in an assembly, transform is under component operations. Under the model tab, select the drop down arrow next to COMPONENT, then component operations. You will see transform there.
Thank you Stephen but i need it in modelling step. For example i'm drawing a crank shaft so that i have to draw many counter weights on the shaft. But i draw one and then i can copy it with transform and rotate operations which are in feature operations. If i do it in assembly, can i save it as part again?
Thank you a lot Lukasz i will try it.
