Aug 19, 2014 10:48 AM UTC
Feature Operations
Hi all,
I have a problem about Creo 3. Feature operations was really vital for me in Creo 2.0 but, in Creo 3 there is Flexible Modeling for it -i think-. I cant use it effectively. It works on surfaces not the solid. I mean when i want to transform something, i cant choose it from part tree. Shortly, is the name of feature operations changed or is it totally removed?
Thank you all.
Aug 19, 2014 12:48 PM UTC
Feature operations menu manager has been indeed removed from Creo 3.0, because PTC feels other functionalities made it redundant. If you're after copying solid features use Copy (or Ctrl + C) and Paste or Paste Special commands. If you want to use translate and rotate options you should go with Copy > Paste Special > check Apply move/rotate transformations to copies option to get dashboard with Move/Rotate options for copies.
Aug 19, 2014 12:09 PM UTC
feature operations i think you would get under-"operations" in creo 3.0
flexible modelling is for direct editing either ..non-native CAD data or native CAD data.
Aug 19, 2014 12:15 PM UTC
operations.jpgYes normally it must be there but I have only these
StephenW
Aug 19, 2014 12:25 PM UTC
When in an assembly, transform is under component operations. Under the model tab, select the drop down arrow next to COMPONENT, then component operations. You will see transform there.
Aug 19, 2014 12:30 PM UTC
Thank you Stephen but i need it in modelling step. For example i'm drawing a crank shaft so that i have to draw many counter weights on the shaft. But i draw one and then i can copy it with transform and rotate operations which are in feature operations. If i do it in assembly, can i save it as part again?
