I am trying to import a step file and would like to use the feature recognition option. I saved the frt_enabled option to "yes" as you can see in my atachment. I'm not sure why the little square icon is infront of the frt_enable command but I still cannot get to the feature recognize option. Can someone help? Thanks
For options with the computer or box looking icon to take effect you need to exit and restart ProE. Options with a lightning bolt take effect in session. Options with a wand take effect only when new files are created (i.e. work when creating new empty part, does not work using start parts).
Kevin
I exit ProE and I still do not have access to the Feature recognition Command. The computer looking icon is still infront of the "Frt_enabled" command even after I exit and return to ProE. Do you or anyone else have any idea how to get access to the Feature Recognition command?
Is the option showing up in the Edit menu and greyed out or is it not showing up at all? It showed up in in the menu after I added the option and restarted ProE. You may need to add the Feature Recognition Tool from Tools>Customize Screen>Toolbars tab. If it's in the menu I think you need to select the geometry first. The icon will remain next to the option, it won't disappear, it's just an indicator of when the option is applied.
