Feature control frame in revision column.
achopade
7-Bedrock
i have created feature control frame as a free note & mention in revision column. but when I suppose to add a new row the location gets disturb. How can I make same as parametric so that when I will add or delete any row its should be in that particular row.
Please refer condition 1 & condition 2
Condition-2: After adding extra row, original location shifts
4 REPLIES 4
rcook
(To:achopade)
If you are creating the FCF with dumb text, you can just create it inside of the table cell. The other option would be to create it as a GTOL, place it as a free note, call it in the table using &g## syntax where ## is the GTOL ID, then delete the free note GTOL.
achopade
7-Bedrock
(To:rcook)
Hello Roger,
Thanks for reply, I have tried the second option (call it in the table using &g## syntax where ## is the GTOL ID, then delete the free note GTOL.) but its not working.
will you please elaborate same?
rcook
(To:achopade)
Ashwin,
Where are you getting stuck? Once you have the GTOL as a free note, hovering over it will give you the ID, then use that same ID in the table cell:
Table cell will look like this:
You can then delete or erase the GTOL that is floating in empty space - the one in the table cell will stay there.
Roger
achopade
7-Bedrock
(To:rcook)
Hello Roger,
Thanks its working. But I need to link that free note as select model & need to select PLACEMENT TYPE: FREE LEADER.
Then & only then I am able to create.
Thanks a lot for your support
