File Version disappear.
mfontaine
I realize that creo 2.0 (M190) delete old version by it's own. I had file up to version 300(exemple.asm.300) but return to a non version file (exemple.asm) after a save.
First i don't want this version to be delete.
Second, its random .... some files have their version deleted not everyone.
It's really weird,
Thanks for your help
17 REPLIES 17
StephenW
(To:mfontaine)
Check your config.pro for the option SAVE_FILE_ITERATIONS
If you want to keep iterations like the the system always has, make sure the value is set to YES.
i don't use this option in my config.pro
is it possible that they chage the default setting in m190
this setting only appears in creo 3.0 in the official documents
StephenW
(To:mfontaine)
Yes, I am on Creo 3 and now that you mention it, I do remember it was a new option.
Are you doing any file backup? That resets all the iterations back to .1
Also, if you are using multiple folders, sometimes the folder "views" don't include the file extension.
I also have seen companies use startup scripts that automatically purge iterations.
very good point but....
i dont do file backup and what it's weird it that the version return to ... no version not even .1
for the folder i check directly in the windows explorer. And for the purge i only use it manually.
i made a test i save like 5 time in a row :
-1rst save reset to no version
-2-3-4-5 increase the version number.
thanks for you time
Dale_Rosema
(To:mfontaine)
Check and make sure that the File Explorer or Windows is set so that it shows extensions. You may no have that turned on, but they are there.
In fact i can see files with version and file with no version so i suppose the setting was fine.
Maxime,
do your test again.
  • create empty folder (for example D:\tmp\creo\test_folder) and save a part five times into it
  • open Command Prompt window
  • enter following command   cd  /D  D:\tmp\creo\test_folder
  • enter following command   dir
  • do you see something like this ?
  • now open Windows Explorer, do you see something like this ?
  • click Organize > Folder and search options
  • uncheck Hide extensions for known file types
MH
Martin Hanák
thanks for the tutorial but my problem is that the version disappear, like i f a had 5 files that represent 5 versions after a save i have 1 file with no version.
Did you follow the steps in artin's tutorial?  If not, please do. It's possible that the version is there but your installation of Windows is hiding it when it is *.1 and not when it is *.2, *.3, *.4 etc.
LinkedIn
i see file with version (1,2,3,5,4,5,6,) and some without.
if its what your saying i'll see no file with version.1 but i see them.
if i open file without version i cant see in the file history that it have and history and a save like 1 days ago.
files for versions were delete, i only have 1 file left.
Interesting.  It does not sound like the Windows setting then, if you are seeing some *.1, thank you for double checking.
From my experience, the first save of a part when created should be *.prt.1, but *.prt is also valid.  However, I'm not sure how that file would be created except manually in Windows.  I'm not sure how else a prt file could be created without the version extension.
This sounds like something you should open a case with PTC tech support on.
LinkedIn
Are you the system administrator for your Creo installation?
Are you using network drives for storage?
Is there anyone else with access to your folders?
Has the system administration mentioned disks are getting too full?
Has the batch file for starting Creo been modified to run a program to purge old files?
Is there a mapkey that's been added or modified that includes purging old files?
Are there multiple locations for files to be stored?
I don't recall ever reading that Creo would just delete files - going back to Rev 13. If there is no other explanation, then perhaps you have a virus program that is deleting files and you just noticed these.
You should be able to go back and look at the trail files and look for cases of opening, closing, and deleting files. If Creo is doing this it will be recorded within Creo, but mapkeys can run OS level commands/batch files and those actions will not be recorded.
I'm surprised that you don't have a Windchill or Teamcenter installation for file management or some other backup system for your data.
The filetype filter for folders is based on an individual suffix basis, though it is not likely your problem. For example, ".1," ".5," and ".8" to ".500" could all be considered known file types and those suffixes hidden, but would show up as repeated, seemingly identical, filenames if there was more than one. Removing a filetype requires changing the Registry to remove those references. PTC install puts in a couple thousand, I think, from .1 to .1999. It's irritating and only makes a difference for drag-and-drop, which I never use.
There is a config option to delete history when using Save-As, otherwise the internal file history should be retained. I think it is a hidden option. purge_history_on_save_copy set to yes
Also see the rest of the discussion about not saving file history: How to clear the audit trail history on the model.
Maxime,
please can you upload picture of Command Prompt windows from your computer showing output of dir command ?
MH
Martin Hanák
i had like 5000 file this is a chunk but i think you will see what you want
2015-12-02  12:07           934 010 d030417.drw.9
2015-12-01  09:34         1 147 941 d030418.drw.1
2015-12-02  12:12         1 166 372 d030418.drw.10
2015-12-07  12:01         1 358 661 d030418.drw.11
2015-12-07  12:02         1 359 681 d030418.drw.12
2015-12-02  10:32         1 129 496 d030418.drw.2
2015-12-02  10:45         1 144 165 d030418.drw.3
2015-12-02  10:45         1 144 363 d030418.drw.4
2015-12-02  10:52         1 142 055 d030418.drw.5
2015-12-02  10:52         1 142 535 d030418.drw.6
2015-12-02  11:59         1 142 259 d030418.drw.7
2015-12-02  11:59         1 143 220 d030418.drw.8
2015-12-02  12:00         1 164 033 d030418.drw.9
2015-05-14  10:36           802 757 do28975-104.drw
2015-05-05  13:04            66 772 dp_x007216.drw
2015-05-12  16:43           109 012 dp_x007216.prt
2015-05-05  13:04           102 446 dp_x007216_flat1.xpr
2015-12-21  14:28            60 071 e201017.prt
2016-04-18  11:06            60 601 e201017.prt.2
2015-11-19  13:00           576 453 e603005.prt
2016-04-27  09:27           602 477 e603005.prt.2
2015-09-08  15:49            59 610 lwb_interior_trim_sa.asm
2013-10-28  11:55         1 819 313 m025615.drw.4
2013-10-31  11:05         1 833 694 m025615.drw.5
2013-12-16  09:59         1 820 037 m025615.drw.6
2013-10-28  11:55         3 442 591 m025615.prt.7
2013-10-31  11:05         3 000 331 m025615.prt.8
2013-12-16  09:59         3 000 454 m025615.prt.9
2013-10-28  11:54         1 499 388 m025616.drw.2
2013-12-13  17:32         1 493 859 m025616.drw.3
2013-12-16  10:00         1 508 413 m025616.drw.4
2013-10-28  11:54           979 124 m025616.prt.6
2013-12-13  17:32           979 064 m025616.prt.7
2013-12-16  09:59           979 542 m025616.prt.8
2015-09-29  08:03         1 999 935 manifold_solid_brep_55.prt.1
2015-10-16  09:09           265 919 p012115_xxx.prt.1
2015-10-16  09:23           263 876 p012115_xxx.prt.2
2015-10-16  09:27           264 985 p012115_xxx.prt.3
2015-10-16  09:58           264 509 p012115_xxx.prt.4
2015-10-16  10:35           264 420 p012115_xxx.prt.5
2015-10-08  10:32           226 269 p012116_xxx.prt.1
2015-10-08  10:38           224 551 p012116_xxx.prt.2
2015-10-15  15:25           223 840 p012116_xxx.prt.3
2015-10-15  14:12           224 456 p012116_yyy.prt.1
2015-10-15  14:18           224 569 p012116_yyy.prt.2
2015-10-15  15:28           224 322 p012116_yyy.prt.3
2015-10-16  09:08           261 664 p012117_xxx.prt.1
2015-10-16  09:23           262 140 p012117_xxx.prt.2
2015-10-16  09:27           262 876 p012117_xxx.prt.3
2015-10-16  09:58           263 337 p012117_xxx.prt.4
2015-10-08  10:32           223 616 p012118_xxx.prt.1
2015-10-08  10:38           222 463 p012118_xxx.prt.2
2015-10-15  15:25           222 620 p012118_xxx.prt.3
2015-10-15  14:12           222 242 p012118_yyy.prt.1
2015-10-15  14:18           222 263 p012118_yyy.prt.2
2015-10-15  15:28           223 072 p012118_yyy.prt.3
2015-10-15  14:08           229 061 p012120_xxx.prt.1
2015-10-15  14:08           224 497 p012122_xxx.prt.1
2015-06-17  12:14            59 699 plenum_adapter_shim.prt.1
2015-06-17  12:17            73 199 plenum_adapter_shim.prt.2
2015-08-27  15:09            67 952 renfort_porte_d1.prt.1
2015-08-27  15:17           164 053 renfort_porte_d1.prt.2
2015-08-27  16:12           341 792 renfort_porte_d1.prt.3
2015-10-16  14:23         2 267 542 roll_up_door_ahs_xxx.prt.1
2015-10-16  14:31         2 276 782 roll_up_door_ahs_xxx.prt.2
2015-09-17  11:35            98 167 strappe_civiere.asm
2015-08-21  08:55           512 725 strappe_civiere.prt
2013-12-18  17:03           926 032 t025004.drw
2013-12-18  17:02           182 565 t025004.prt
2013-12-19  15:37           972 763 t025005.drw
2013-12-19  15:37           185 429 t025005.prt
2013-05-09  12:11           846 088 t025050.drw
2013-05-09  12:11           196 538 t025050.prt
2013-08-29  10:58         1 189 226 t025128.drw
2013-08-29  10:58           244 435 t025128.prt
2013-07-11  11:57         1 001 953 t025129.drw
2013-07-11  11:57           272 256 t025129.prt
2013-12-05  10:31           321 761 t025130.prt
2013-07-11  11:42         1 038 483 t025131.drw
2013-07-11  11:42           288 465 t025131.prt
2013-12-19  16:08           874 731 t026300.drw
2013-12-19  16:08           261 787 t026300.prt
2013-12-18  17:15           755 372 t026301.drw
2013-12-18  17:14           119 040 t026301.prt
2013-12-18  17:24           837 205 t026302.drw
2013-12-18  17:23           137 287 t026302.prt
2013-12-18  17:48           955 214 t026303.drw
2013-12-18  17:47           394 382 t026303.prt
2013-12-19  10:22           780 157 t026304.drw
2013-12-19  10:22            87 470 t026304.prt
2013-12-18  18:29         1 113 649 t026305.drw
2013-12-19  16:31         1 234 305 t026305.prt
2013-12-18  18:47         1 111 874 t026306.drw
2013-12-19  16:31           865 156 t026306.prt
2013-12-18  18:59           762 737 t026307.drw
2013-12-19  16:31            89 375 t026307.prt
2013-12-19  09:16           870 856 t026308.drw
2013-12-19  16:31           147 018 t026308.prt
2013-12-19  09:19           738 426 t026309.drw
2013-12-19  16:31            84 118 t026309.prt
2013-12-19  09:08         1 105 733 t026310.drw
2013-12-19  09:08           459 255 t026310.prt
2013-12-19  08:49           861 044 t026311.drw
2013-12-19  08:49           338 860 t026311.prt
2013-12-19  08:34           719 106 t026312.drw
2013-12-19  08:34            79 477 t026312.prt
2013-12-19  08:28           764 171 t026313.drw
2013-12-19  10:22           113 008 t026313.prt
2013-12-19  16:51           179 908 t026314.asm
2013-12-19  16:51         6 484 099 t026314.drw
2015-05-19  10:36            19 384 t028199.drw
2015-05-19  10:36           105 314 t028199.prt
2014-12-16  11:42            47 735 t028200.drw
2014-12-16  10:33           161 030 t028200.prt
2015-05-19  17:15            68 146 testplate_assy.asm.1
2015-09-14  16:42           100 757 trail.txt.1
2015-11-20  15:29            10 601 trail.txt.2
2016-02-17  12:27            15 268 trail.txt.3
           45099 fichier(s)   55 226 885 515 octets
               2 Rép(s)  535 012 945 920 octets libres
i:\CAD\Composantes\Serie_DEMERS\025000-029999>dir
Le volume dans le lecteur I s’appelle DATA
Le numéro de série du volume est D8B7-BC56
Répertoire de i:\CAD\Composantes\Serie_DEMERS\025000-029999
2016-06-08  08:27    <DIR>          .
2016-06-08  08:27    <DIR>          ..
2016-06-08  08:27           151 730 025000-029999.idx
2015-06-03  11:43         1 073 441 a0128114-101.drw.1
2015-06-03  11:43           473 944 a0128114-101.prt.1
2015-06-03  11:46           698 794 a0128114-101.prt.2
2015-06-03  11:47           697 055 a0128114-101.prt.3
2015-06-04  08:45           702 922 a0128114-101.prt.4
2015-06-03  11:44         1 073 105 a0128114-102.drw.1
2015-06-03  11:44           696 919 a0128114-102.prt.1
2015-06-03  11:46           469 128 a0128114-102.prt.2
2015-06-04  08:13           456 476 a0128114-102.prt.3
2015-06-05  09:26           456 114 a0128114-102.prt.4
2015-06-26  15:25           655 452 a0128114-102.prt.5
2015-06-30  13:58           659 326 a0128114-102.prt.6
2015-07-03  13:58           643 407 a0128114-102.prt.7
2015-08-04  12:15           654 246 a0128114-102.prt.8
2015-06-03  11:44         1 073 105 a0128114-103.drw.1
2015-06-03  11:44           696 970 a0128114-103.prt.1
2015-06-03  11:46           469 145 a0128114-103.prt.2
2015-06-03  11:50           440 908 a0128114-103.prt.3
2015-06-04  08:12           456 889 a0128114-103.prt.4
2015-06-05  09:26           456 412 a0128114-103.prt.5
2015-06-26  15:25           655 486 a0128114-103.prt.6
2015-06-30  13:58           660 437 a0128114-103.prt.7
2015-07-03  13:58           644 229 a0128114-103.prt.8
2015-08-04  12:16           651 121 a0128114-103.prt.9
2015-06-03  11:44         1 073 103 a0128114-104.drw.1
2015-06-03  11:44           697 036 a0128114-104.prt.1
2015-06-03  11:50           674 733 a0128114-104.prt.2
2015-06-03  14:59           694 491 a0128114-104.prt.3
2015-06-08  20:01           690 711 a0128114-104.prt.4
2015-06-30  15:21           951 841 a0128114-104.prt.5
2015-06-03  14:59         1 073 101 a0128114-105.drw.1
2015-06-03  14:59           694 887 a0128114-105.prt.1
2015-06-04  08:45           703 003 a0128114-105.prt.2
2015-06-03  11:40         1 073 425 a0128114.drw.1
2015-06-03  11:40           473 903 a0128114.prt.1
2015-07-16  08:04            97 841 a023403-901.prt
2013-04-30  09:36           113 335 a025002.asm
2013-04-30  09:40         1 406 789 a025002.drw
2013-09-16  14:53           206 633 a025019.asm
2013-07-16  14:58         1 376 973 a025019.drw
2015-03-02  09:45           382 436 a025022.asm
2013-05-29  16:54         3 369 391 a025022.drw
2013-05-23  10:00            98 910 a025028.asm
2013-05-23  10:00         1 123 591 a025028.drw
2013-05-23  08:57           100 660 a025030.asm
2013-05-24  07:38         1 114 880 a025030.drw
2013-05-23  09:12            97 409 a025034.asm
2013-05-24  07:40         1 118 273 a025034.drw
2013-05-24  07:43            99 603 a025036.asm
2013-05-24  07:43         1 104 510 a025036.drw
2013-05-23  09:42           100 929 a025038.asm
2013-05-23  09:42         1 140 775 a025038.drw
2013-05-23  10:36           102 519 a025040.asm
2013-05-23  10:36         1 115 052 a025040.drw
2015-10-15  14:09           184 254 a025043.asm
2015-03-02  09:51           256 129 a025044.asm
2014-02-26  16:25         3 406 807 a025044.drw
2015-03-02  09:51           924 680 a025045.asm
2014-02-26  16:25         4 342 213 a025045.drw
2014-01-28  11:46           477 420 a025059.asm
2014-01-28  11:46         2 176 420 a025059.drw
2014-04-29  14:25           117 655 a025060.asm
2014-04-29  14:25         1 158 098 a025060.drw
2013-05-22  14:43           118 319 a025061.asm.1
2013-05-22  14:58         1 305 402 a025061.drw
2016-03-29  11:41            96 947 a025063.asm
2016-04-21  16:45            97 431 a025063.asm.10
2016-04-22  10:06            97 915 a025063.asm.11
2016-04-25  12:27            98 179 a025063.asm.12
2016-04-26  14:59            98 262 a025063.asm.13
2016-04-27  16:29            99 716 a025063.asm.14
2016-05-02  13:32            99 970 a025063.asm.15
2016-05-06  11:15            97 980 a025063.asm.16
2016-05-06  17:16           110 140 a025063.asm.17
2016-05-09  10:21            99 754 a025063.asm.18
2016-05-11  16:39           101 465 a025063.asm.19
2016-04-07  12:05            98 645 a025063.asm.2
2016-05-16  16:25           100 689 a025063.asm.20
2016-05-17  16:34           102 113 a025063.asm.21
2016-05-18  16:49           102 786 a025063.asm.22
2016-05-19  12:47           103 189 a025063.asm.23
2016-05-19  16:43           103 514 a025063.asm.24
2016-05-20  12:48           102 869 a025063.asm.25
2016-05-24  14:40           104 156 a025063.asm.26
2016-05-25  10:04           104 172 a025063.asm.27
2016-05-30  12:18           104 425 a025063.asm.28
2016-05-31  12:07           104 829 a025063.asm.29
2016-04-08  14:46            98 869 a025063.asm.3
2016-06-01  15:21           104 798 a025063.asm.30
2016-06-06  09:35           115 494 a025063.asm.31
2016-06-07  14:51           106 361 a025063.asm.32
2016-04-11  16:30            99 159 a025063.asm.4
2016-04-13  12:25            85 585 a025063.asm.5
2016-04-14  12:01            97 301 a025063.asm.6
2016-04-15  10:13            97 699 a025063.asm.7
2016-04-18  12:11            97 051 a025063.asm.8
2016-04-20  11:17            97 410 a025063.asm.9
2013-08-16  11:29           133 349 a025066.asm
2013-05-29  09:12         1 821 060 a025066.drw
2013-08-21  09:13           113 638 a025067.asm
2013-08-21  09:13         1 921 387 a025067.drw
2013-08-21  09:13           115 447 a025068.asm
2013-08-28  10:48         2 517 303 a025068.drw
2013-08-21  09:12           113 126 a025069.asm
2013-08-21  09:12         2 033 604 a025069.drw
2013-05-17  15:18         3 766 577 a025071.drw
2013-05-27  16:50           324 281 a025073.asm
2013-05-28  11:40         3 846 266 a025073.drw
2015-05-27  14:05           172 505 a025077.asm
2016-04-08  15:54           154 798 a025077.asm.2
2013-07-09  11:22         1 918 358 a025077.drw
2015-05-27  14:02           172 781 a025078.asm
2013-08-21  09:13         1 937 916 a025078.drw
2013-07-04  12:08           135 019 a025081.asm
2013-07-04  14:19         1 257 822 a025081.drw
2013-07-04  14:00            87 816 a025082.asm
2013-07-04  14:20           976 170 a025082.drw
2013-06-26  09:16           104 287 a025091.asm
2013-06-26  09:31         1 616 734 a025091.drw
2014-03-12  15:34           115 246 a025093.asm
2014-03-12  15:34         1 236 741 a025093.drw
2013-06-28  08:27           114 065 a025095.asm
2013-06-28  08:27         1 220 796 a025095.drw
2013-06-12  14:45           112 415 a025111.asm
2013-06-12  14:37         1 185 757 a025111.drw
2015-02-25  16:47         2 482 216 a025116.asm
2013-07-08  11:54         5 235 507 a025116.drw
2015-12-21  16:20           107 335 a025119.asm
2014-02-14  17:10         1 072 042 a025119.drw
2014-04-15  14:02            84 254 a025126.asm
2014-04-15  14:02         1 790 804 a025126.drw
2014-08-25  14:15           227 013 a025133.asm
2013-07-15  15:11         1 934 505 a025133.drw
2013-07-15  11:52           330 241 a025135.asm
2013-07-15  11:52         2 200 817 a025135.drw
2015-07-03  08:29            88 667 a025137.asm
2013-07-15  13:09         1 597 836 a025137.drw
2014-02-19  14:59           120 120 a025140.asm
2014-02-19  14:59         1 380 119 a025140.drw
2016-01-20  09:36           207 932 a025142.asm
2013-08-12  14:40         1 427 403 a025142.drw
2013-08-19  08:47           134 031 a025148.asm
2013-08-19  08:47         1 412 771 a025148.drw
2015-05-14  14:14           146 708 a025158.asm
2013-12-10  14:51         1 143 418 a025158.drw
2014-06-05  11:12           145 532 a025159.asm
2013-12-10  14:58         1 073 330 a025159.drw
2015-11-09  11:45           115 667 a025161.asm
2015-11-09  11:45           948 699 a025161.drw
2015-11-09  12:03           597 330 a025163.asm
2015-11-09  12:03         1 878 877 a025163.drw
2014-06-18  09:01           102 451 a025165.asm
2013-06-13  11:03         1 017 533 a025165.drw
2014-07-01  16:42           144 992 a025173.asm
2014-07-01  16:18         2 126 616 a025173.drw
2014-07-01  15:42           130 715 a025174.asm
2014-07-08  11:32         2 261 421 a025174.drw
2015-11-16  12:35           105 050 a025176.asm
2015-06-04  09:05            45 797 a025176.drw
2015-06-30  15:49           137 932 a025179.asm
2015-06-30  15:50           542 844 a025179.drw
2016-03-04  13:31         1 107 080 a025181.asm
2016-04-12  09:33         1 134 525 a025181.asm.2
2016-04-12  09:34         1 134 471 a025181.asm.3
2016-04-12  10:41         1 133 766 a025181.asm.4
2015-11-23  09:40         4 296 083 a025181.drw
2016-04-12  09:33         4 478 234 a025181.drw.2
2016-04-12  10:41         4 481 651 a025181.drw.3
2015-09-23  13:33         1 073 813 a025182-101.drw
2015-12-15  13:05           950 493 a025182-101.prt
Almost all of the files without a version extension are older, a quick scan shows only one in 2016, some in 2015 most in 2012-2014.  Some have newer versions with a numeric extension.
I can't tell you how the version-less files were created, but they weren't created recently and it seems that Creo is properly incrementing them as they are opened and saved.
LinkedIn
Maxime,
thanks for publishing file list. All file names are correct.
In case of file names without numerical extension - Creo acts as if these files have .1 extension. For example Creo assumes that a025063.asm has the same meaning as a025063.asm.1
If you open Command Propmt window, change current directory to i:\CAD\Composantes\Serie_DEMERS\025000-029999 and enter command dir a025063.asm* then you will get little bit confusing listing - this confusion is caused by alphabetical sort order:
If you open Command Propmt window, change current directory to i:\CAD\Composantes\Serie_DEMERS\025000-029999 and enter command dir /od a025063.asm* then you will get better listing - this is caused by date sort order:
In the above list you can see complete file creation history.
As Doug Schaefer mentioned - nobody is able to explain why some file do not have numerical extensions. Numerical extensions could be removed by custom purge command -OR- by PDM system used at your workplace. Ask your colleagues, administrators, IT, ...
MH
Martin Hanák
