Fix Comp
dbowles
Fix Comp
Anyone have any issues with using fix component in WF4.0?
Since they repaired the ref des problem I have fixed all connectors with no
problems.
I believe pro-e fixes the components the same as if you did a measure
transform from default and hung them on a csys.
Tried to search for some data on this from PTC, did not find much.
Douglas K. Bowles
Advanced Systems Harn/Des
520-665-7082 Office
520-490-9395 Cell
PRIVACY ACT NOTICE: This communication may contain privileged or other
Official information. If you are not the intended recipient or believe
that you have received this communication in error, please reply to the
sender indicating that fact and delete the copy you received. It is a
violation of Federal Law to print, copy, retransmit, disseminate, or
otherwise use this information without prior authorization.
0 REPLIES 0
