Flexible Move by Dimension for Cylindrical Objects
shussaini.r
I would like to make a flexible move of a boss with dimension. When I tried it was possible to move with dragger, but in case of dimensional move, I am not able to pick the reference. Can anyone just let me know how to make that move?
psobejko
(To:shussaini.r)
Did you add the datum axis as a reference (into the "Move curves and datums" collector like my screenshot shows)?  If not, you won't be able to select it for dimensioning...
5 REPLIES 5
What reference are you trying to pick?
psobejko
(To:shussaini.r)
Yes, it's possible to do this move; you might have to make a datum axis first, though:
I tried that but I was not able to pick the datum axis as reference for that move.. That's where I was confused. I tried to select a flat surface and along with that when I tried to select the datum I am not able to it, the datum axis is not getting highlighted.. is there anything which I am missing out here?
psobejko
(To:shussaini.r)
Thank You so much!! You are right. I was missing that and now I am able to successfully move it.
