Is there a way to attach GD&T symbols to threaded or clearance hole callouts on a drawing or part?
"Kevin Demarco" wrote:
Here are two options you have. First, show the diameter of the hole. 1. Create the hole note callout by adding the hole feature parameters to the dimension. This will look something like: @D-&THREADS_PER_INCH:FID_59[.0] &CLASS:FID_59 etc. (The number 59 is the Feature ID.) 2. Create the hole note as a separate note and remove &METRIC_SIZE from the note. Add the threads per inch parameter to the dimension and hit enter to leave a space. Note should look like: @D-&THREADS_PER_INCH:FID_59[.0] Set your draft grid to.125 and turn on snap to grid. This will allow you to position the thread note to the dimension. Group the note to the dimension so they move together.
