Get the parameter list of a model
ddhini
I have a model .I want to get that model parameter in a Excel file.We can get it by Tools=>Parameters=>File=>Export. By this we can easily export the parameters of the model into csv file.But i Want to get the list of parameters list by j-link program for a Standard Comparison.Is possible to get the list of Parameter?Suggest some Idea.
3 REPLIES 3
Use for loop to load the required parameter from the model using
IpfcParameterOwner.GetParam("Parameter Name")
then export as *.csv
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
ddhini
(To:PARTHIBAN_K)
Thanks for your response.Can you explain it brief?
sjuraj
(To:ddhini)
IpfcParameterOwner is for example Model object because it inherit from IpfcParameterOwner. So for instance do: session.GetCurrentModel().GetParam("param name")
