Hatching error in drawing (Creo 10)
MohanS
3-Newcomer
Hi I'm trying to create an offset section (See the pic attached). While showing the section on drawing, I'm not getting the hatch properly.
MartinHanak
(To:MohanS)
the problem can be "model related".
Suggestion: Create simple test model and try reproducing the problem on it. In case of success upload it.
Martin Hanák
8 REPLIES 8
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
http://kotom.eng.free.fr
MohanS
3-Newcomer
(To:Kotom-Eng)
Sorry. I was new. Anyways it has been partially resolved. I'll post there from next time.
BenLoosli
(To:MohanS)
I built an offset section in Creo 9.0.9.0 and Creo 11.0.0.0 and both displayed the cross hatching as expected.
What build of 10 are you using?
MohanS
3-Newcomer
(To:BenLoosli)
Hi Ben, it is 10.0.4.0
There is a solution I posted in martin's comment sections below. Thanks.
MartinHanak
(To:MohanS)
Martin Hanák
Thanks Martin!
I tried recreating a similar section in another simple model, just to check if the issue is with Creo settings or something. But it worked there.
Strange! I don't know what's wrong in the model, but I found an interim solution:
It works when I create the section before hole featues.
Dale_Rosema
(To:MohanS)
Try moving the bottom hatch line .001" left or right and see if that works.
Thanks Dale, but I tried the same. It did not help. There is a solution I could manage to find. (Please see Martin's trailing comments)
