Hi I'm trying to create an offset section (See the pic attached). While showing the section on drawing, I'm not getting the hatch properly.
the problem can be "model related".
Suggestion: Create simple test model and try reproducing the problem on it. In case of success upload it.
You are in the wrong forum.
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
Sorry. I was new. Anyways it has been partially resolved. I'll post there from next time.
I built an offset section in Creo 9.0.9.0 and Creo 11.0.0.0 and both displayed the cross hatching as expected.
What build of 10 are you using?
Hi Ben, it is 10.0.4.0
There is a solution I posted in martin's comment sections below. Thanks.
Thanks Martin!
I tried recreating a similar section in another simple model, just to check if the issue is with Creo settings or something. But it worked there.
Strange! I don't know what's wrong in the model, but I found an interim solution:
It works when I create the section before hole featues.
Try moving the bottom hatch line .001" left or right and see if that works.
Thanks Dale, but I tried the same. It did not help. There is a solution I could manage to find. (Please see Martin's trailing comments)
moved from Creo 8 to 10, the drawing mode is absolute garbage, can we get the menu driven options back? The hatching is awful, can't export a hatch from one drawing anymore it seems. When moving a sybmol, where the heck is on entity moved to, I don't see it anywhere! Why do they keep changing and wanting everything to be ribbons and symbols, just absolute trash, the memory seems to be less as well, drawings and assy's just show up blank and you have to close and reopen creo. Decent eng laptop as well and it was not an issue in creo 8
