Help Needed: Images in Creo keep disappearing
JaneH
I am having a problem with images that are inserted to surfaces of parts. After inserting an image, I saved the file close Pro-E completely. After re-opening Creo, the image disappears, but the part surface is still in its specified color. I thought it could be a file reference issue, but the image will disappear regardless of where the file is located.
VladimirPalffy
(To:JaneH)
Hello Jane
Place your source images for textured colors must be in the working directory (for one project).
Vladimir
Note: Place your images to: creo_dir\Common Files\M020\graphic-library\textures\
(for all yours projects).
Best Regards,
Vladimir Palffy
