Help with coding inside a bom table
ptc-5441279
Hi all
I am working inside a BOM table calling out the part description in one of two different languages. The parameters that I am calling up are: &asm.mbr.PART_NAME or &asm.mbr.DESCRIZIONE. My problem is that I want to display the DESCRIZIONE only if PART_NAME does not exist. I am using Creo elements 5 if that has any affect.
Thank you
Wayne
TomU
(To:ptc-5441279)
This is pretty straight forward. Add these relations to your repeat region and then change the parameter of the description column to be &rpt.rel.BOM_DESC
BOM_DESC = ""
IF EXISTS("ASM_MBR_PART_NAME")
BOM_DESC = ASM_MBR_PART_NAME
ELSE
IF EXISTS("ASM_MBR_DESCRIZIONE")
BOM_DESC = ASM_MBR_DESCRIZIONE
ENDIF
ENDIF
1 REPLY 1
TomU
(To:ptc-5441279)
BOM_DESC = ""
ELSE
ENDIF
ENDIF
