Hi it is possible hightlights component in an assembly drawing when i select a baloon or a row in a repeat region table?. By default it's not possible
Someone know a work around to do it
Thanks a lot
Fabio
Not that I've noticed through Creo 2.x
Why do you want to?
Hi Fabio,
If you select the row from the repeat region table, the BOM balloon, if shown, will highlight. But the component does not.
Amit
