Hi have quite the extensive Hole chart that fills 2 sheets in my Creo 10 Drawing.
All was going well until I noticed I lost my Hole Designations that tells me in the hole chart its dimensions.
I have had one other person have the same experience.
Anyone know how to get them back?
Hi @DE_13274042,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
Please post a screenshot of your hole chart headers (fields) and a few data.
Personally, I do not use Hole-Charts as I find them meaningless with CNC machining. Use them to merely designate the holes as A, B, C etc.
Hole charts are unidirectional. Meaning, if you add a hole or delete a hole from the model, the hole chart has to be created again.
Hence, I prefer to give an Ordinate dimension for the holes and specify say e.g. Dia 20 H7 THRU for holes Marked A/B/C etc.
Hope I have understood the question correctly.
