Hallo,
I would like to ask you, if there is any possibility to have more than 9999 rows in one table? I have cca 23 000 datum point and I need to get their possitions for next steps. Or do you know any other way how to do it?
Thanks for your answers
How are these datum points defined? Try using feature->feature info and then extracting the data from the text file...
Thank you, it seems good. How exactly can I get to this Information window? I tried many ways but nothing worked (I am using Creo 2.0)
I don't have Creo running right now. But generally, you right click on the point feature in the model tree, then info->feature info.
