How can I find irrational dimensions? e.g. 1.242354363
rhudd
I've recently received several Creo models and drawings. In a few drawings I've noticed that while some dimensions are displayed as 5.00 they are actually 5.001325334....
Is there anyway I can quickly find such dimensions without having to manually interrogate each one? I can then fix these dimensions in the model.
mbonka
(To:rhudd)
Hello rhudd
try following in drawing space.
1. Active Annotate bar - set filter to dimmension (right bottom corner)
2.  Select all dimmensions in your drawing (with mouse)
3. Press RMB - select properties - set decimal places to 30
4. Find "bad" dimmensions
Hope it can help
Regards
Milan Bonka
mbonka
(To:rhudd)
Hello rhudd
Hope it can help
Regards
Milan Bonka
rhudd
(To:rhudd)
Thanks for the suggestion, this is a nice approach that works well.
