I have a question that I always save my part and cover other file. I open my file to continue designing my project,but I always forgot where I open my file and what is my file name.
I know that Proe have two save function.(save and save a copy) I think that Creo Elements/Direct. has save function like "save a copy" in creo.But I need function like save. It let me not look for file path and remember file name.
Thank you for your replying
Because your session can contain multiple PKG files, Creo Elements/Direct Modeling does not try to keep track of the directories from where the PKG files were loaded. And it gets further complicated by the fact that a single PKG file can contain a single part or multiple parts.
If you use the "SD Data" file type instead of the PKG file type, that will keep track of the directories for each file.
