How can I save pkg like save of creo function
yhuang-2
11-Garnet
I have a question that I always save my part and cover other file. I open my file to continue designing my project,but I always forgot where I open my file and what is my file name.
I know that Proe have two save function.(save and save a copy) I think that Creo Elements/Direct. has save function like "save a copy" in creo.But I need function like save. It let me not look for file path and remember file name.
Thank you for your replying
1 REPLY 1
Because your session can contain multiple PKG files, Creo Elements/Direct Modeling does not try to keep track of the directories from where the PKG files were loaded. And it gets further complicated by the fact that a single PKG file can contain a single part or multiple parts.
If you use the "SD Data" file type instead of the PKG file type, that will keep track of the directories for each file.
