I have been sent a number of DRW files and am trying to view their content. Is there any viewing software package that will allow me to do this? I have downloaded a Trial version of CREO 4 and it will not open them. Is there something I need to do or have installed for this software to actually work? a sample file is attached if that will help
You have at least 2 problems:
You can try Creo View Express.
https://www.ptc.com/en/products/plm/plm-products/creo-view/extension-express
I don't remember the details but I think that is the drawing was saved with the correct options, it will be viewable.
I tested on 2 drawings, one worked perfectly and the other one, a very large drawing, had issues.
As Randy said, if you need to open the drawing in Creo Parametric, the drawing does not stand alone, you will need all the model files (.asm, .prt, etc.).
1ZSE528002-DE_EMC filter.drw is invalid name - somebody rename the file outside of Creo. If you open the file in Notepad++ you can see this:
2.)
I renamed 1ZSE528002-DE_EMC filter.drw to drw0003.drw
3.)
File > Open > click arrow on Open button and change it to View Only
You will see this result.
Over 20 years using this software, I didn't know this option existed! How long has this been possible?
When I try this the format is still getting loaded and I don't see anything in the drawing views. Not sure how useful this is...
Edit: Apparently "save_display" has to be set to "yes" for this to work. Read all about it here: http://support.ptc.com/help/creo/creo_pma/usascii/#page/detail%2FAbout_View-Only_Mode.html%23
save_display yes ... enables users to see "picture of the drawing" in Creo ViewOnly mode
save_drawing_picture_file embed ... enables users to see "picture of the drawing" in Creo View Express application
