Morning everyone
I want to add a note in my drawing, to show the full path of where my drawing is stored. I only need to do this on drawings that are filed under
special directories.
Any Ideas??
Fred J. Matthis
I use 2 mapkeys for this windir creates a text file with the file path and dir runs windir and then prompts for a location for a note.
mapkey dir @MAPKEY_LABELnote of windows directory;%windir;\Fred,
The full path of all files opened in Pro/E is written to your trail file. Perhaps using the mapkey provided previously along with some scripts of some sort you can extract the information from the trail file.
Here is a sample of the info in the trail file for a simple assembly I just opened. Note that all files openedare written to the trail file as "Start/End" pairs.
!Command ProCmdModelOpenExe was pushed from the software.
!16-Jun-10 08:45:17 Start c:\thellen\dbatch_assy.asm.1
!%CPSelect a simplified representation name.
~ Timer `UI Desktop` `UI Desktop` \
`EmbedBrowserTimer`
~ Activate `open_rep` `OK`
!16-Jun-10 08:45:20 Start c:\thellen\9146a.prt.28
!16-Jun-10 08:45:20 End c:\thellen\9146a.prt.28
!16-Jun-10 08:45:20 End c:\thellen\dbatch_assy.asm.1
Ron
