How do I include parameters in "copy geometry"
bp
Basically I have a skeleton part with a parameter "number_of_holes".
Also I have a number of parts which all have a pattern feature using "number_of_holes". How do I get this parameter from the skeleton part?
vzak
(To:bp)
If you really need Copygeom to carry over the parameter you need to attach this parameter to original geometry. You can attach parameter to Surface (you will have to name this surface first). When you get parameter attached to surface, then Copygeom of this surface will have same (and synchronized) parameter on it.
If however parameter belongs to anything else (feature, part) - then you will have to downstream it with the help of relation.
10 REPLIES 10
neomechanikos
(To:bp)
Since a copy geometry only copies the geometry there's no way to pass the parameter itself through the feature. You can however pass the geometry of a pattern from the skeleton to the downstream part. Just create a pattern of axes, points, or holes, etc. in the skeleton and then create a copy geometry feature in the part that references the first member of the skeleton pattern and nothing else. Then reference-pattern that copy geometry in the part(s). Your pattern will be created in the part so effectively you've passed the "number of holes" geometrically. If you change the pattern in the skeleton, it will update in the parts(s).
If you want to pass a parameter directly to other models, you'll need to use a notebook.
bp
(To:neomechanikos)
I tried the reference pattern trick, but "reference pattern" is grayed out in my part containing the geometry pattern (I created a pattern of axis in my skeleton and added the first member to the Publish Geometry).
What now?
dgschaefer
(To:bp)
Since the publish geom is not a part of a pattern, there's no pattern to reference. You need to reference pattern the publish geom as well.
With this technique, I find that the publish geom is an extra complication that is not needed. I simply grab the pattern leader directly in my copy geometry in this case which means one less step, and one less pattern.
A publish geom is useful for gathering up lots of data to share. Since here we can only share one thing in order to make the ref pattern work, the publish geom is of no value.
LinkedIn
bp
(To:dgschaefer)
Allright, I got the ECG (External Copy Geometry) succesfully patterned in my part using Reference, then I created a hole to reference pattern.. but again Reference is grayed out! What is it this time?
neomechanikos
(To:bp)
Did you reference the first instance of the copy geom pattern when you created the hole?
bp
(To:neomechanikos)
I started over and now it works (probably I used a wrong reference, the modeltree was already clogged a bit with lots of ECG's). At the moment I can only get it to work with the " hole" feature. If I create a plane normal to the axis and create an extruded cut, I still cant select "reference". Oh well..
vzak
(To:bp)
bp
(To:vzak)
One last question, I still cant create extrudes with reference-pattern (using an axis and a new plane as reference, the axis comes from a circular pattern in a skeleton), only holes. I dont get it, is this a bug?
Also if I create a reference pattern of a new axis using the skeleton axis as reference and then reference pattern a hole on the new axis pattern, i get an error
bp
(To:bp)
Stop looking for a solution everybody, I just figured it out.
In order to succesfully reference pattern an extrude feature on a circular pattern, you need to include the sketchplane in the pattern by grouping this plane with the extrude and then patterning this group. (otherwise the pattern members of the extrude cant find their sketchplanes )
WayneSchrock
(To:bp)
I use INPUT & EXECUTE to pass all my parameters.
