How do I remove the file extension from the file name parameter.
RD_9833370
3-Newcomer
I am creating a new drawing format and in the table where I show the file name I am using the parameter &PTC_WM_NUMBER. So if the file name is 123456abc.prt it shows up in the tile block as 123456abc.prt.
I want to find a way to remove the extension .prt or .asm and just show the file name "123456abc".
TomU
(To:RD_9833370)
Number is a Windchill parameter.  If you want the file name then use &dwg_name for the drawing's name and &model_name for the model's name.  Neither of these will include the file extension.
See more here:  https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/#page/detail%2FSystem_Parameters_for_Drawings.html%23
2 REPLIES 2
TomU
(To:RD_9833370)
RD_9833370
3-Newcomer
(To:TomU)
Thanks, I knew the answer was simple.
