How do you scale down an igs file?
ptc-5066368
I am fairly new to Creo and having problems getting an igs file I recieved down. We are trying to reduce the size of the part down by 20%, so that it can fit into our assembly properly. Can someone please explain what the easiset way to go about this is?
Thank you in advance
On the 'Model' tab in the 'Operations' group, click the little triangle at the bottom to expand it and you'll find the 'Scale Model' command.
LinkedIn
LinkedIn
Thank you very much for the help!
