How to correctly sweep through this curve?
pkristof
3-Newcomer
Made this curve through points, it supposed to be a conveyor belt
When i tried to make a simple sweep, drew a rectangle at the starting point, it swept it along the trajectory by rotating the rectangle, based on the curve's direction. So the rectanlge didn't remain normal , and I couldn't figure out which setting to use
So the question, how can I make this sweep, so the rectangles sides stay normal to something, and doesnt rotate?
Or is there an alternative way to do this? I just want a rectangle section along the curve
Here's the file : files.fm/u/dpqvzrxw#
Thanks!!
12 REPLIES 12
Hi, did you find any solution to this problem?
I know it's been 7 years, but I have a similar problem with control of my sweep and preventing an unexpected twist.
Van_AG
(To:pkristof)
Set "Section plane control" to "Normal To Projection" in sweep References.
And set datum plane witch will define orientation for sweep section.
@Van_AG thank you , but can you please be more specific? I have about 25 planes in this design, I know you don't see them.
That rectangle must be rotated 90 deg, so the angle that now has 51.9155 deg should have 90 deg and the other one should have 0 deg.
I'm not sure which datum plane to pick as it doesn't generate anything when I do. It doesn't allow me to sketch the profile anything when I do.
Which planes to pick?Which planes to pick?
1 must be parallel to 2 and right angle between 3 & 4. The turn to bottom left must be flat as well, with the bigger surface on the top.
Van_AG
(To:AJ_12152667)
Can you share the trajectory curve please.
I'll try to explain
Here goes the file @Van_AG , Hope it works.
Van_AG
(To:AJ_12152667)
Please see the attached models.
Trajectory segments "Intersect 1" and "Intersect 2" not tangent to neighbors, so I recreate them in r3-model
Thank's @Van_AG it does look lovely now.
Can you expand on the steps so we all can understand what is the process please?
I see what you did, but since this tool is new to me, I don't quite understand HOW did you do it 😊
I see that you have created additional sections in here, and set them up to main XY plane, great move.
I suppose, this is what you mean by setting the tangency? This tool seems to be a very powerful one. Can you guide us to some extensive tutorial perhaps?
tbraxton
(To:AJ_12152667)
I would encourage you to create a new thread specific to your model and issue. I have posted here an example of how to manage the trajectory of the corners which I think provides what you are looking for. In general, one would like to have a minimum of G1 (tangency) continuity along the entire sweep trajectory. With less than G1 continuity in the trajectory it usually results in undesired geometry when used for sweeps.
I have enclosed a model (Creo 4) where I have "managed" the corner transitions in a way that imposes tangency such that you can use the sweep normal to trajectory option to get a "good" corner transition. Note the corner has a single tangent transition where the two radii meet in 3D space.
Involute Development, LLC
Consulting Engineers
tbraxton
(To:tbraxton)
Illustration of corner control using two radii. This paradigm can of course be implemented for splines and 3D curves (ISDX) to get a desired transition in the corner as well. It is possible to impose continuity at G2 and G3 in some cases if needed.
I have tried that before as you can see in my model. There is a tricky part because a sum of radiuses can't be higher that distance from bottom to top trajectories. If the sum is lower, then one can generate a intersection path.
Thanks for the model and explanation. They look fine. In my model it is rather a feature than an error 😉
Can you explain, how did you generate Section1  in your model please? I can see this, but my guess is that it comes from  Curve from Cross Section. Please confirm if that is the case.
tbraxton
(To:AJ_12152667)
I do not understand what section you are asking about (section 1). If you are asking about a specific feature, what feature #? I did not use curve from cross section when building the model.
The sketches used for the surface extrusions were manually sketched.
