How to covert the solid weld feature to a component when save as to PVZ file in Creo Parametric?
Patton_Mi
8-Gravel
How to covert the solid weld feature to a component when save as to PVZ in Creo Parametric? Is it possible to set export_pvs.rcp to conver solid weld to component  in pvz file displayed in Creo View? When I open assembly model with welding solid features, the function worked.
Please help to check it. Thanks.
This is the test steps:
1 Create weld assembly in Creo Parametric 8.0.8.0
2 Save as to PVZ file with a customized rcp file.
3 In Creo View MCAD 10.0.0.0, open pvz and asm file.
Refer to the files attached
please open Case at PTC Support.
Martin Hanák
Hi MartinHanak
Thanks for you feedback. I have opened the case C17005205. Hope to get the solution from TS.
Best Regards,
Patton Mi
