How to covert the solid weld feature to a component when save as to PVZ in Creo Parametric? Is it possible to set export_pvs.rcp to conver solid weld to component in pvz file displayed in Creo View? When I open assembly model with welding solid features, the function worked.
Please help to check it. Thanks.
This is the test steps:
1 Create weld assembly in Creo Parametric 8.0.8.0
2 Save as to PVZ file with a customized rcp file.
3 In Creo View MCAD 10.0.0.0, open pvz and asm file.
Refer to the files attached
please open Case at PTC Support.
