Hi guys I am very new to Creo, how can I import a 3D part and build 2D sketch based on it ? Thanks guys ![]()
Hi Yat,
Depending on what you are trying to do, you can create a Sketch feature and use the Project command to create a sketch using the edges of the 3D model.
You can find additional information in the Help Center. The information is located under:
File > Help > Creo Parametric Help
Creo Parametric > Part Modeling > Sketcher > Creating Sketcher Geometry > Creating Geometry from Model Edges
Please let me know if you have any further questions.
Amit
