How to create gap/space in between two dimension line
SM_10367631
2-Explorer
Can someone show the method how can i get this space in between dimension line?
How to break the dimension line to allow another line go through?
CREO VERSION 9.0.6
2 REPLIES 2
use Insert Break command presented in uploaded video.
Martin Hanák
One can use the "Cleanup Dimensions" command under Annotate Tab --> Edit Group.
What you wish to break in the pic is the "Witness Line" and not the "Dimension Line"
Tick mark the "Break Witness Lines"
Regards
Srinivasan Iyer
