Can someone show the method how can i get this space in between dimension line?
How to break the dimension line to allow another line go through?
CREO VERSION 9.0.6
use Insert Break command presented in uploaded video.
One can use the "Cleanup Dimensions" command under Annotate Tab --> Edit Group.
What you wish to break in the pic is the "Witness Line" and not the "Dimension Line"
Tick mark the "Break Witness Lines"
