How to create greyscale Postscript files?
ocorten-2
9-Granite
Hopefully an easy one:
Has anyone found a way to let ProE create Greyscale Postscript files?
I could not find any .pcf setting to disable the colors.
Problem:
We have drawings like these:
For years, when printing in batch mode, we have been sending color postscript files to our Black&White printers.
These were printed in greyscale like this:
Now we are switching towards color printers.
The postscript files are treated as is, so now they are printed in color.
Any tips on how to force or change the postscript files to greyscale?
This is our current .pcf file
plotter POSTSCRIPT
button_name Print A3
button_help Print using Windows Printer Manager.
delete_after_plotting yes
paper_size A3
paper_size_allowed A3
plot_drawing_format YES default
plot_segmented NO default
plot_roll_media NO default
plot_label NO default
plot_handshake software default
create_separate_files NO default
plot_with_panzoom YES default
rotate_plotting NO default
plotter_command WINDOWS_PRINT_MANAGER
plot_name NO
interface_quality 3 default
pen_table_file c:\ptc\FicoPTC\ProE\plot_config_dir\pen_table.pnt
plot_sheets current default
paper_outline NO default
plot_clip NO default
plot_area NO default
Kind regards,
Olaf Corten
Olaf Corten
CAD/PLM Manager
Fico B.V.
Ratio 6, Duiven
Phone: +31 26 3196215
Mobile: +31 644548554
www.besi.com
Confidentiality Notice:
This Email, and any attachments, may contain internal or confidential information and is intended solely for the individual to whom it is addressed. It may contain sensitive or protectively marked material and should be handled accordingly. If this Email has been misdirected, please notify the author immediately. If you are not the intended recipient you must not disclose, distribute, copy, print or rely on any of the information contained in it or attached, and all copies must be deleted immediately.
Hi Olaf,
can you share with us your pen_table.pnt??
-nk/.
dgallup
(To:ocorten-2)
I don't think pen table files will affect shaded views. You might have some luck with Ghostview. In the convert menu there is a properties dialog box. There are all kinds of properties you can set about down sampling color images and gray images. I poked around a bit but did not find anything that worked for me in a couple of tries.
There is also a pcxgray device that sounds like it's gray scale but I don't have a PCX file viewer.
PTC quality philosophy: We've upped our quality standards. Up yours.
Thanks all for your replies.
Looks like you can't create greyscale Postscript files from Creo Parametric/ProE.
There are tools to convert color Postscript files to greyscale (Adobe, Gimp).Or you can Print/Save As to PDF in greyscaleAnd off course you can change the default in your windows printer driver to greyscale.
Still you would need to press the OK button in the windows printer dialogue
But all these workarounds are not what I wanted: let ProE create a greyscale postscript file.
We use the postscript files for batch printfile creation followed by batch printing.
So we can't have any user interference in setting preferences or accepting windows printer dialogues
The solution we have now found was a setting on the Canon printers.
It will now treat all raw printfiles (like our color Postscript files) as B&W instead of Auto (Color and B&W)..
We can now only print in color when printing through the local printer driver.
So from ProE we create the Postscript file (which is still in color) and ProE uses a low level method to send the file to the printer.
e.g. print /D:\printerserver\CanonPrinter c:\temp\printfile.ps
Problem solved .....
Kind regards,
Olaf Corten
Olaf Corten
CAD/PLM Manager
Fico B.V.
Ratio 6, Duiven
www.besi.com
To: -
Date: 01-10-2012 14:41
Subject: [proecad] - How to create greyscale Postscript files?
Problem:
plotter POSTSCRIPT
paper_size A3
plot_name NO
Kind regards,
Olaf Corten
Olaf Corten
CAD/PLM Manager
Fico B.V.
Ratio 6, Duiven
www.besi.com
Attachment Links: blankfilename.txt (12 k) blankfilename.txt (10 k) blankfilename.txt (12 k) blankfilename.txt (2 k) blankfilename.txt (1 k)
Site Links: View post online View mailing list online Send new post via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
