How to create multiple shapes with relation for a burning cylinder , save S. Area for each step?
- 11 replies
- 13131 views
- Translate All
Hi friends,
I'm trying to simulate the geometry change for the burning of a perforated cylindrical shape (solid fuel inside a rocket motor) that burns from inside and both sides. I want to recede the thickness with 1 mm until the cylinder completely burned. How can I change the dimensions automatically and obtain the surface area of the new geometry at each burn step, then how to plot these areas with the new thicknesses of the cylinder, or export the results to Excel? I know there is a way by using relation (make the dimension function of the thickness), creating a family table for that automatically generate the new model shapes, saving the surface areas for each new shape, and plotting the areas as a function of each thickness. I tried to do that by myself but I failed.
I really appreciate any kind of help as I have to complete a Ph.D. paper according to this geometrical analysis and the submission date is on the 31st of July. I attached here (as a hint) some relevant work using NX software. whoever interested, I can add his name as a co-author of the paper as well.
