Hi, everyone, I found the Normal constraint in the Creo assembly very annoying, I don't want to use it at all, but seems it is the default Constraint, everytime I choose two surfaces, Normal constraint comes out, so I would like to know if it is possible to disable the Normal constraint, or change the default constraint to Concident?
There are is a config option related to the angle for which a normal constraint applies by default which can help, though just picking Coincident first will avoid it.
see:
comp_normal_offset_eps
Specifies the angle epsilon such that if the desired surfaces are equal or less than the epsilon (in degrees), then a normal constraint will be created (default is 10 degrees)
I expect that when you first add the model you will see that the surfaces start close to normal in the default orientation.
Perhaps a negative value will disable it?
see:
Hi, dschenken, thanks for your replying, it worked unless the angle is 90 degree.
Hello zhihong li
l´m almost sure, there is some hidden config.pro option for this demand. Try to search following link with all hidden options.
Search Pro/ENGINEER config.pro options
Personally have found nothing useful for you ![]()
Let us know if you will find some config.pro options.
Regards
I haven't seen the normal constraint in years.
For eliminating the normal constraint from happening by default:
comp_angle_offset_eps 91
comp_normal_offset_eps -1
Add this option to get it to default to coincident instead of distance:
auto_constr_always_use_offset never
As l discovered, there are 3 config.pro options familiar with this problem.
1. auto_constr_always_use_offset --- control whether auto constrait should create offsets.
YES - Auto canstraint always creates offsets
NO - Auto constraint snaps align or mate if surfaces are within tolerances
NEVER - Auto constraint never creates offsets
2. comp_angle_offset_eps --- Specifies the angle epsilon such that if the desired surfaces are equal or greater than the epsilon (in degrees), than angle offset constraint will be created.
3. comp_normal_offset_eps --- Specifies the angle epsilon such that if the desired surfaces are equal or less than the epsilon (in degrees), than angle offset constraint will be created.
Regards
