How to model an elliptical gear using creo v2.0
kbose
2-Explorer
step by step procedure for designing and modeling an elliptical gear would be very much helpful as i didnt get any material for it , the same for spur gears are vastly available but nothing in detail are available for non circular gear,pls help
mbonka
(To:kbose)
Hello Kiran,
have never seen "elliptical gearing" 3D parametric model. l can share my evolvent_angular_bearing parametric model. Think the way to your model will be similar, but more complicated.
See attached file.
Milan
kbose
2-Explorer
(To:kbose)
Thank you steven , I'm facing an issue on how to draw the tooth profile as you imported the tooth profile from the sketch palette.It would be very helpful if the sketch of the tooth profile is available.
dschenken
(To:kbose)
Check out www.Gearotic.com
GearoticMotion3.mp4 - YouTube
